I built my RV-6 22 years ago, it first flew on July 1, 2002. It's been it's whole life in Florida so not only was the original paint beginning to show its age, but there were a few areas of minor corrosion around the airplane that needed to be addressed. It was time to give this airplane a new lease on life. I did an extensive condition inspection this year which included among other things a new cowl with Skybolt fasteners, new gear leg fairings with wooden stiffeners topped with new gear/fuse intersection fairings, new wing root fairings, and a whole bunch of other stuff including two permanent service bulletins to the horizontal stab. The paint shop I chose is located in Sebastian, FL, an airport that is about a 5 minute flight from my home base, Vero Beach, FL. After arriving at the paint shop, I completely disassembled the airplane so that each surface could be painted individually. The airplane was chemically stripped, but afterwards was completely sanded down to bare metal using DA sanders. Then alodine and Akzo primer, and the white base coat. Next, I had to make several trips to the paint shop to temporarily install control surfaces for masking purposes and then remove everything again. Final striping, then final assembly. This all takes a lot of time. Total time in the paint shop was about 3 months. While there, I removed the prop to replace the fan belt which I believe was the orignal belt on the airplane.
Anyway, finally got it home this week and I'm quite happy with the result. It's like a new airplane for me. A few pictures:
