RV10 Performance profile in ForeFlight
CJT
Has anyone entered different RV10 performance profiles in ForeFlight & checked accuracy?
When I had the highest level FF subscription, I played around with advanced profiles - I created one that had different speeds, climb rates and fuel flows by altitude but I found that the basic one actually worked quite well (image attached). Fuel consumption for 2 hour flights are usually within 0.5-1 gallon. I didn't track ETE vs ATE as closely but I think it was pretty close. This profile worked well for 1-2 people on board. For a heavier load (and hotter conditions), I have a different profile with a lower climb rate.
Since I wasn't using much of the highest level feature set, I downgraded to the middle level.
Vas
Vas
