I did a very uneven job of countersinking my aileron attach bracket - the rivet head is undercut on one side. What do you think? Replace?
I emailed vans a while back, but have not heard from them on this. I'm sure they'll get to it eventually.
I would appreciate your wisdom. Also, tips on countersinking so close to things - I tried to do it by hand and that didn't work out so well.
Drilling out rivets in such thick material is not very easy, so I'm worried about potentially damaging the wing rear spar while removing this if I did want to replace it. I see there were directions in Section 5 (I think) to use a #40 drill and then punch it out, which is what I'd try here.
