647jc
I am fitting my Vans FB spinner and I see in the instructions Van says you can use round head or CS #8 screws with recessed washers. For the CS screws he says to use a #19 CS to accommodate the recessed washer. To CS deep enough to accommodate the CS washer, you will end up enlarging the screw hole since the FB is not thick enough to really accommodate the CS washer. What have others done regarding this? Is there some other washer that works better, are washers really required, the CS can be made deep enough to accommodate the screw only but that fastening may not be strong enough.
