howardtlcc
When we install the Matco wheel the hole for the cotter pin in the axle nut is right at the end of the axle. I see one solution is to slot the cotter pin holes. Any ideas on how to accomplish that?
Another solution was to mill 1/4 inch off the end of the axle nut. But, you need a lathe for that plus won't that screw up the fit of the wheel pants?
Anyone run across this?
thanks
Howard
thanks
Howard
