As Larry mentioned - process for a 7, goes quick and relatively easy... 2 people for most of it is what I found best.On the 7, Vans is pretty specific about the order of riveting. Basically an "L" pattern toward the outboard. It's not difficult with two people. The last rivets are bucked by sticking an arm through the outboard rib holes. Slip and old sock over your arm.
Whatever you do, think of gravity and what a dropped bucking bar will do. And trust me, it will always land corner-down.
Towels-a-plenty below whatever are you are working on.
A dropped bar will find that lightning hole in the spar and generate maximum velocity towards the leading edge.
Those bars can be downright evil!![]()
I notice that you have pretty much everything installed, including the aileron actuation hardware. The plans call for installing the bottom skins after the aileron actuation hardware, but I was thinking about doing the aileron stuff first, too. Was riveting difficult with the torque tubes and autopilot servo hardware installed?Here's what I came up with to get the skin out of the way while I try to reach the most aft rivets. Seems like it might work. At least I can reach them with my bucking bar in one hand while banging with the other. We'll see. Hopefully, the fact that six of the seven straps are not Snap-Ons will not affect the results.
