MA4-5 10-4164-1 carburetor
Scott Hersha
Friend
My O-360-A1A powered RV6 has a 10-3878 carburetor. Last month I read an article by Vic Syracuse (don’t remember which publication) about two RV6’s he was working with at His Base Leg business. Both of them had issues with high CHT’s. There were a couple problems that could cause this. One was ignition timing, but both of them had the 10-3878 carburetor. Vic said that the correct carb for our airplanes should be the -4164 - larger main jet, among other things. I believe he upgraded those two RV6’s to the -4164 carb, and they saw a marked improvement (I think). I have a fixed pitch Sensenich GA prop on mine. At full takeoff power, once airborne I’ll see 2250 RPM, ~28-29” MAP until I pick up some speed, but my fuel flow at that full power setting is 13-13.2 gph. On warm days I’ll have to reduce my MAP to 25-26” after I’ve climbed a couple thousand feet to keep my hottest cylinder(s) below 400*. In cruise my CHT’s slowly balance out in the neighborhood of 330-350* depending on OAT. So - question is - for those of you that have gone this route, did it help with high CHT’s, and what other indications have you experienced in other phases of flight? For the engine experts, what would you recommend. Vic - am I right about what I think you said about the -3878?
I always use the 4164 on RV's for the higher FF. You can use the 3878 as the return core.
Carb‘d lycoming equals poor fuel distribution. Our RV air intake is really really high, which makes for a lean mix which we cannot control. I suffer the same on my O320 GA prop 6A. Your fuel flow is correct based on, baro, temp and RPM right? I understand the issue, in the Deep South in summer my initial climb is a little flatter for me too. I called MS and discussed, yep different carb was their recommended path if I wanted higher fuel flow at this phase of flight. Easier for me to pull back on the black knob for a minute or two, get past this worrisome issue, then enjoy the remainder of my flight….which is 99% of the flight 😀
When I bought my -6 rapid acceleration on take-off or during a GA caused the engine to kind of hesitate, and the FF was the same as yours Scott. The Mooney mod with a bigger main jet cured that a few years ago.
My new engine should be on the build next month (🤞) and will be fitted with a new 10-4164-1 to replace the current 10-3878...
D & G Supply also recommended by my A&P friend at my airport, and Jimmy at JBA. I called Russ at D&G and he will basically turn my 3878 into a 4164 - for about $150! What a good deal. Our airport closes on June 3 for about 6 weeks and that’s when the carb will come off. Also planning on putting a taper pin in my tail stinger during that time.
These temps seem perfectly fine to me (and to Mike Busch, and to Lycoming). If it went over 420 in climb maybe I’d consider a little baffling tweak. What am I missing?
I’m sure it would go over 420 in a full power climb on a warm day (in fact or has) if I didn’t pull the power back a little. That’s not OK with me, and the carb mod should fix it, because it has worked with so many others. The 3878 becomes a 4164 with the mods. That’s the carburetor that should be on this airplane.
Research MA4-5 Mooney Mod kit
It basically conveys your carb to a 4164.
Made a big improvement on my RV-6A.
+1.
I had lean WOT issues with my 3878 on an O-360. The Mooney mod kit has a larger main jet and also a restrictor for the economizer cct which makes the carb run richer at WOT. May not completely solve your high cyl head temps on climb but you won't be lean at WOT any more.
Since the OP has an O-360, I am assuming that the 4164 is applicable to that motor. Or would that swap work for an O-320? I may be looking at an similar issue on my O-320 E2A equipped 9A.
O-320 uses the MA4-SPA carb (smaller than the MA4-5) so your solution would be different.
A good carb overhaul shop should be able to help you determine if there is a different ten dash # carb that would be desirable for your engine.
On a O-320, I had luck with the 10-3678 carb. Makes 14+GPH on takeoff
Interesting discussion, but, it brings up a question on my engine/carb setup. I have an O-360-A1D from a salvaged Piper Geronimo Apache; the carb that came with this engine was a 10-3878. Prior to installation on my RV-8 I had the engine field overhauled, plus sent the carb out for overhaul as well. The engine and carb were installed together and have been running well for over 17 years and 2100+ hours, no real issues other than occasional high CHTs on a hot day climb.
So now my question is, why was the 3878 carb adequate to run on a Geronimo Apache, but when the exact same engine is installed on an RV, it needs the 4164 carb? Is it a speed/airflow/baffle/cooling thing?
Different induction air boxes can have an influence on what the actual fuel air mixture ratio ends up being when it leaves the carb
Yes, I believe the higher speed plus more efficient air box makes some carbs run leaner than optimal. What’s your takeoff fuel flow?
The carb on my O-320 is a 10-3678-32 that was fitted on the Piper Cherokee donor. There is also another 10-3678-12 carb that is leaner I think (I am not 100% certain). I hope that yours is a -32 because then mine should be OK too!
Exact fuel flow I don't recall off the top of my head... but dang, now I feel like I need to send my carb in for an upgrade.
Yes, I believe it’s the -32
I think that was the situation with the Mooney’s in the 90’s, and they modified the main jet, and maybe a couple other things to allow more ff at full throttle (Mooney mod). That basically morphed the 3878 into the 4164. Our RV’s have a similar situation because of speed/airflow into the carb.
Well I’ve had enough, thanks for the thread. Sending my MA-4SPA 10-5217 o320 D1A FP to D&G Monday morning. 600+ flights of data shows max FF 11.4 on departure, settling down to mid/lower 300’s in cruise. Mentioned the 10-3678 that some have had good performance from, but also appreciate their recommendation. This padt Thursday, departing with OAT 86F @ sea level, multiple cylinders getting too far north of 400F . Slow climb to manage temps whilst being beat up by rising air 🥴 proved too much without trying something to better the situation. Thanks for the vendor recommendation and other info.
Scott and Tom,
I'm curious about this. The venturi in the carb is essentially an air flow meter that measures the flow locally inside the carburetor, and then puts the (hopefully) right amount of fuel to go with it. A well-designed carburetor should deliver the correct air-fuel ratio over a pretty wide range of airflow. So - why would airplane speed or induction air box design influence the air-fuel ratio?
My guess is that there is inevitably some airflow distortion at the carburetor inlet, and the non-uniformity of flow probably means that there is somewhat less airflow than the venturi thinks there is. Jet tuning gets the air-fuel ratio right in the presence of that non-uniform flow. Now, a different air box would have different inlet distortion, and a well-designed air box may have very little distortion, so, more total air flow for the same local airflow at the venturi, and that would require a slightly bigger jet.
Sound right?
Scott and Tom,
Sound right?
My thoughts have always been pretty much the same.
Like you said, the physics of a Venturi fuel delivery system should always be self compensating but we know it is not.
I know of instances where people tried to fly without the air filter installed in there air box and the engine ran horribly. There is clearly some type of flow disturbance that is benefiting from the influence induced by the air filter.
Scott and Tom,
Sound right?
I don’t know the answer.. I just was under the impression that a more efficient airbox, more “ram” than a Cessna might make requires more fuel. I just know that the 3678-32 runs more fuel and cooler CHTs than the 5217 or replaced.
It seems to me that a certain sized main jet will allow a certain amount of fuel to flow through it at a certain amount of cfm of airflow. It makes sense to me that a larger jet would allow for an increased FF (gpm ) at a given Venturi airflow. It has worked well for others, so I’m going to try it. I think our RV airbox might allow an increased carb throat velocity than what has been accepted as standard. The Mooney airplanes have a system that allows you to bypass the normal filtered inlet, and allow a straight air inlet, bypassing the filtered inlet and permitting a straight ram air non-filtered carb air induction inlet. This results in about a 1 psi increase in MP when implemented after takeoff. Apparently results in an increase in airflow through the carb that results in a leaner mixture because the 3878 standard carb jet provide enough FF to accommodate the increased airflow…….. hence the “Mooney Mod” That essentially converts a 3878 Into a 4164. I’ll be sending mine to D & G in a couple weeks and let you know the results when I get them……. unfortunately not until late July because they are closing my airport for 6-7 weeks for runway upgrades. Time for upgrades/mods.
I spoke with Russ at D&J Monday. Sent in a spare 10-5217 and ask if he could flow it to 14gph. The carb had a sticking float and was replaced with new. Hoping to do as Scott, cool things a bit on initial climb. I mentioned your success with 3878 vs 5217.
My experience with the 3878 on a stock PV O-360 is that it will run much too lean at WOT. The Mooney mod, which I did, incorporated 2 changes. It had a one size larger main jet. It also had a restrictor for the air passage on the economizer cct, which adds more fuel only at WOT (not sure why they call it an economizer cct). This increased my WOT fuel flow from 13 to 16 USGPM. Mooneys ran lean with this carb as well hence the "Mooney Mod". FWIW.
Just to clarify, there are two conversations going on here, one group with a O-320, and another with the O-360.. different carbs. I was suggesting the 3678-32 for the O-320. (You mentioned a 3878, not the 3678)
I mis typed, 3678-32, not 3878. Thanks
A key point here is that the carb is designed to deliver the right amount of fuel for a certain amount of air, AS MEASURED AT THE VENTURI. In some installations, the inlet flow may be rather non-uniform, so that other areas of the carb throat, not at the venturi, may have reduced pressure/flow. In other installations, the inlet flow may be more uniform, resulting in more total airflow for the same MEASURED airflow at the venturi. A carb that has been tweaked to work well in the first case will be too lean in the second case. That is my theory anyway.
Well, carb shipped, over hauled, the flow was increased , and returned in 10 days at a fair price. Regrettably with NO CHANGE in FF seen by my very accurate FF metering. More reading makes me think a larger jet, doesn’t mean it will flow higher if venturi / airflow is kept same. Disappointed ☹️
That’s disappointing. I sent mine into D&G and got it back a couple days ago. It’s installed but I can’t fly yet. My airport is closed for runway resurfacing. It won’t open for another month at which time I’ll be on a vacation in N Michigan, so another 6 weeks for me. I told Russ I would like to see 15+ gph at takeoff (O-360 fixed pitch). He installed the 666-660 kit and put a new 4164-1 data plate on it. I will hopefully report better result at the end of July.
With email conversations I learn it was only increased 8%, a meager .921gph. Per vendor they never increase more than 12%. I paid for overhaul just to get this carb reflowed. Now I have two ma4spa 10-5217 , neither giving me what I want. In retrospect, I should’ve purchased 3678-32 and used my broken needing overhauling as core. Same $$$ basically 🤦‍♂️
Vendor said return it and they’d tweak more……😀
Thanks Butch. Good to know if I need it tweaked. When they made the new data plate on mine (originally a 3878), they stamped +15 at the very bottom, so I’m guessing when they flowed it, that’s what they got. Of course what they get on a flow bench might be different than what I will see with my airbox in flight.
Only the fuel injected Mooney models have a fliter bypass ( M20 E,F and J using the angle valve 200HP IO-360 Lycoming), none of the carbed Mooney models have a fliter bypass.
I Received my carburetor back from D&G reflowing it higher; BINGO 14 gph at 2700 rpm. Departing today 92F and no CHT above 380F . D & G are awesome to work with, delivering exceptional service in all regards. Thanks Tom for the insight as to the O320 needs. You were spot on 👍🏻 This is not a 3678-32, but a high flowing 10-5217. I can now get the climb performance numbers of my RV without high CHTs.
