I need to shorten this throttle cable extension (not sure what it’s called) by about 1/8” of an inch.
I had to adjust the throttle arm on new carb due to some geometry issues ( cable hits oil pan at full throttle ) and it needs to be shortened by 1/8-1/4”.
Or can these be cut ?
I can get a picture.If you can get a side view pic of your cable routing to the carb, there are lots
Of folks here that can help you determine if you need a different carb bracket or modification.
You may need a proper extension to replace the aluminum tubing in the picture. Aircraft Spruce has this:
Extensions For Threaded Controls | Aircraft Spruce ®
Extensions For Threaded Controls Use these stainless steel extensions for moderate length adjustments to stock length controls. Stocked with one male and one female threaded end. Also available with two female threaded ends. Th...www.aircraftspruce.com
Or follow the suggestion and replace the current control cable with the new control cable with the appropriate length.
Yep, you definitely need the correct bracket from Van's. The engine control cable sleeves need to be attached to the engine at the engine end (hope that makes sense)....that is, they need to be able to move with the engine as it vibrates. Yours are currently mounted to the engine mount which is rigid mounted to the airframe. The result is any engine movement has to be taken up by the short solid cable end running from the engine mount to the throttle arm. Not a good setup. And...the same thing is happening for the same reason with the mixture cable.This is a picture of what I currently have as throttle bracket and mixture bracket.
I have an email in to VANS asking which of the cable brackets they recommend for a lycoming O-320 D3G and RV-6. They seem to have two options. Both clamp between the carb and sump and provide a location to affix the cables for the carbs. Once I get the proper part to order will do so and then order new cables as required.
If someone knows which of the brackets are correct that would be great although I can wait for vans to respond. Any third party options appreciated as well
Thanks again for the advice.
Vans has the recommended length for the various engine control cables. I think I found the paper plan has the length for the RV8. You can order a custom made cable from Aircraft Spruce and it provides a nice webpage interface so you can pick and choose the end fittings that will fit your aircraft.Concur. Working with VANS to identify the correct part. It looks like it’s backordered. I may put out a cry in the wilderness in the classified section to see if anyone’s got one once I know what the vans status is.
Thanks.
You don't really want air leakage in that location, on either side of the bracket. Get two new gaskets. One between the sump and the bracket, one between the bracket and the carb. Aircraft Spruce carries both Lycoming 66224 or Superior SL66224.I have the correct bracket inbound thanks to another member..
One really dumb question I have as a prepare to install.
It looks like this bracket clamps between the carb and the sump. Does this require two gaskets. One between the carb and the bracket and then one between the bracket and the sump?
Or just a single gasket?
