I currently have old Prinston Puck sytle sender and need to replace them, I am looking at the Cies senders (1 per tank).
Do they use the same size screw as factory?
How many gallons will be unreadable with a single sender?
Has anyone installed the sender while attached to the wing or should I remove the tank?
Welcome commits on if its worth the mod to go with 2 per tank.
TIA
TIA
