6 Lycoming IO-540 Cylinders from Lycoming factory rebuild. Asking $5,800 US.
Redmantice
6 Complete Wide Deck Lycoming Cylinder Assemblies (less piston pins and plugs) for sale.
- cylinder No. 6 - LW-12427 / 118757 / LW-12397
- cylinder No. 5 - LW-12427 / 118757 / LW-12397
- cylinder No. 4 - LW - 12427 / 118757 / LW-12367
- cylinder No. 3 - LW - 12427 / 118757 / LW - 12397
- cylinder No. 2 - LW - 12427 / 118757 / LW - 12397
- cylinder No. 1 - LW - 12427 / 118757 / LW - 12397
All Pistons are labeled 1 to 6 with the number “14D23912” which is Lycoming Part No. 75089
- They were installed on an AEIO-540-D4A5 bearing the Serial Number L-25993-48E which was overhauled at Lycoming (Williamsport, PA) on April 13, 2015.
- It sat until 2021 when it was installed in my RV10. Unfortunately the mechanic who installed it forgot to take out the aerobatic inverted oil plug and ran it for 1 hour. This did not cause damage to the cylinders but did affect the bottom end of the engine.
- the engine was removed and sent to AeroSport Power in Kamloops for assessment. They confirmed no damage to the cylinder assemblies and recommended their reuse. I opted for a complete new engine with higher compression cylinders.
- I kept the cylinders for the past 2 years with the intentions of using them on another project - but have decided against it.
- I have all the paperwork from the overhaul and correspondence from AeroSport Power.
- these are not superior millennium cylinders.
- pictures and supporting information upon request.
- Also available:
—> Slick Magnetos (Left and Right) - Sold to Wayne M - thank you!
1. Serial No. 14110923, Model No. 6393),
2. Serial No. 15020493, Model No. 6350)
—> Precision fuel Servo - model RSA-5AB1, serial no. 70DT 9003, part no. 257650 7-3 - sold to Aden R - thank you!
—> 24V MagnaFlite Starter. Part No. MHR - 6016,
—> Lycoming motor mount ears (small hole).
My name is Jay Conlin. My number is 780-two-nine-zero-01-eight-one.
What type are they: wide deck or narrow deck?
Was the cylinders new at engine overhaul or were they overhauled too?
I have been informed that a fella by the name of “SAM JOLLY” is attempting to hijack my listing. I am not associated with this fella.
I’m very familiar with these cylinders and the bearing failure with the engine. These are essentially new Lycoming cylinders (not rebuilt or reconditioned). I used “essentially new” because they were brand new when Jay and I flew behind them for 2 short flights before we knew something was seriously wrong with the bottom end of the engine and it needed a thorough inspection. I would buy these and keep them for when I need a rebuild but I have a narrow deck engine in my 10 and these are wide deck.
The ad has been updated with additional information regarding part numbers. I have roughly 44 pictures that I can forward to those interested.
Estou muito familiarizado com esses cilindros e com a falha dos rolamentos do motor. Estes são essencialmente cilindros Lycoming novos (não reconstruídos ou recondicionados). Usei “essencialmente novos” porque eles eram novos quando Jay e eu voamos atrás deles em dois vôos curtos antes de sabermos que algo estava seriamente errado com a extremidade inferior do motor e que precisava de uma inspeção completa. Eu compraria estes e os guardaria para quando precisar de uma reconstrução, mas tenho um motor de deck estreito no meu 10 e estes são de deck largo.
Ele escreveu que o cilindro tem uma plataforma estreita...
