This is the tubes Vans sent with my finish kit. There is no way to service air pressure without removing the wheel pants and the wheel nut. Actually I had to bend the head of the pin 90 degrees for the cap to clear during rotation and it's still to close for comfort. I called tech support and they said that this is the first they had anyone complain about it. I was told to send photos into [email protected] and they would look at it. Is this the same tubes that Vans has always sent with the RV 10?
should be a bent stem instead of the straight. If they don't replace them I'll be spending another $250 for new tubes.
