I am in the process of redesigning my legacy RV-12 electrical system. To free up more panel space I am going to replace my Van's Fuse and Switch Module with a Vertical Power VP-X electronic circuit breaker box. Besides switches and fuse, the Van's panel apparently also has a current sensing shunt. I say apparently because I'll be darned if I can figure out where it is. I was expecting to find an appropriate copper shunt with sense wire whiskers on it but so far no joy. Is it possible they implemented the current sensing shunt with just a PCB trace? Using a PCB trace for current sensing is notoriously inaccurate but maybe accuracy isn't that big of a deal. Still...
Anyone know where the current sense element is in the Fuse and Switch Module?
Anyone have an recommendations for an external current sensing shunt for use with the VP-X ECB?
Attached are a few pictures for reference. BTW, that last picture I attached is some less than acceptable soldering I found on my panel. This solder bridge shorted around the 30 amp generator fuse. Nice!
