Majorpayne317641
I’m retrofitting to the vans electric trim kit from manual trim. I’ve got the tab set up and I noticed in the construction manual under the test chapter is says I should have trim tab 35 degrees down and 25 degrees up. Am I miss reading something? I can only get 30 degrees down and 14 degrees up. I measured my friends RV-8 and he has it biased more tab up then down (more nose down trim ability). I can always fly and see when I run out of trim on either side. But I’d like to get it roughly close.
