semiller1184
I’m sure this has been done, but has anyone made their own stick grip? I’m looking for ideas.
Wow, that looks great. Thats impressiveI made these stick tops and just used a foam grip below.View attachment 55041
You should sell those !! Very nice and simple but has what's needed.I made these stick tops and just used a foam grip below.View attachment 55041
I would have thought that you never wanted the stick - as opposed to control stops - to limit control motion, inverted or not.And for the simpler kind, carved this out of a limb cut off the apple tree in my yard. Only has a push to talk. The rear one came out better, that is what is pictured.
Having the rear stick in the the -8 means you can't do full inverted (stick hits the seat back) so it is usually out of the plane. That's why I have it home to take a picture. PTT wire was too long, so looped it back around explaining the extra wires. Should cut off that extra weight, but since I leave it on the ground all the time anyway ...
That's excellent. It would be ergonomically very nice to hold, too. Good choice!Here's the one in my RV-3B I'm slow-building.
It's light, meets the goals of KISS and best of all, I like it.
www.kitplanes.com
