What about J243 pins 8 & 6? Read section 23.4.8
Manual says second source can be used and it will display the higher of the 2 values. However, schematics in the install manual show only one input for pmag (one wire shielded) so it looks like the only connection will be signal (pin8) from a single mag to the GEA24.What about J243 pins 8 & 6? Read section 23.4.8
Webb, Per the Emag manual, you only need a tach input from one Pmag because the tach signal will still transmit even when you select that mag off during the run up.Manual says second source can be used and it will display the higher of the 2 values. However, schematics in the install manual show only one input for pmag (one wire shielded) so it looks like the only connection will be signal (pin8) from a single mag to the GEA24.
