'Outside Air temperature' probe position
lots of threads on that topic. Those that have measured after moving from that location say it reads almost 10* above ambient.
I have seen many that have put it there but have heard that it gives inaccurate readings in that location. I put mine, as many do, about 6" back of the leading edge and about 6" below the horizontal stab. Seems accurate in that location. FWIW.
I put mine in the Vans-standard location for the bent-tubing pitot tube - and then installed a Gretz mounted heated pitot for IFR work. The OAT is just the perfect size to fill that hole.
I have 2 OAT sensors on my 9A. One is in the wing fairing, installed by the builder, and it is 8+ off. One in the middle of the last wing access panel, I installed with an AV-30 and it is spot on. One of these days I am going to extend the sensor in the wing fairing.
Has anyone fitted their 'Outside Air temperature' probe in the NACA vent, is this a good place, or not
I did originally. seemed a bit higher due to engine heat. I res-positioned under the wing in the first inspection bay. Now my true airspeed is accurate. Worth the change.
I have one in each NACA vent on different sides of the fuselage. The one in the SUN always reads higher.
See Dan Horton's (DanH) post above on recommended location that I think they should be.
