backcountry
I want to check my pitch settings.
The tool I have has two settings 2 and 3.
Is this the correct one to use on the RV-12?
Use of the pitch adjusting pins has never been recommended for the RV-12 because it was found that the accuracy varies widely from one propeller to another.
Scott:
Does that apply to the larger Sensenich props with pitch pins, for example on RV6/7 with Lyc IO-360s? (Sorry to intrude on the RV-12 section, but have not been getting a reply elsewhere.)
Scott:
I just ordered TOOL-00002. Can’t wait to see how far out the pitch pins are (Sensenich GA prop - RV6).
I prefer to check this by careful measuring the elevation above a point marked on the ground rather than using a level on the hub which can have a small amount of variability depending on how you read it each time (a very small rotational position change of the propeller can show up as a difference in the measured angle).
I like this and will incorporate your idea. Well documented...
My Vans kit came with a pitch pin 2 & 3. What I would like to know is this a good pitch this a good pitch setting for the RV-12.
I originally set the pitch with the Digital method back in 2017. My plane climbs faster and cruises slower than the other 5 RV-12 on the field.
I want to check out different pitch settings. I’d like to use the Sensenich pin and fine adjust with the Digital method.
So what I’d like to know is has anyone set the pitch on a RV-12 using the Sensenich pin. If so what PIN number did you use. That way I’ll have a starting point
