backcountry
I understand there’s VOR antennas that can be bonded on the inside fiberglass and wonder if anyone has tried that inside the RV-12 engine cowling?
Why put one of these ugly eye pokers on your airplane when a wingtip VOR/LOC/GS antenna fits the bill? Mine works to 100nm+ out and LOC/GS way beyond practical range.Why not just mount the antenna on the vertical fin like many other aircraft?
Like Carl, my wingtip mounted 30-year old Archer nav antenna works to a longer distance than needed.Why put one of these ugly eye pokers on your airplane when a wingtip VOR/LOC/GS antenna fits the bill? Mine works to 100nm+ out and LOC/GS way beyond practical range.
Do you recommend putting your wingtip antenna inside or outside the RV-12 metal wingtip?Why put one of these ugly eye pokers on your airplane when a wingtip VOR/LOC/GS antenna fits the bill? Mine works to 100nm+ out and LOC/GS way beyond practical range.
I haven't done it (I'm going the WAAS GPS only route) but I understand routing that antenna cable up through the tail is a non-trivial task.Why not just mount the antenna on the vertical fin like many other aircraft?
My intention was to show an alternative approach to the VOR/LOC/GS antenna installation for the RV-12. Thin wires bonded to the inside of the aft canopy is an easy installation. Routing the cable to the receiver is also easy compared to a wing tip or vertical stab installation. And the antenna performance is every bit as good as the conventional locations.I haven't done it (I'm going the WAAS GPS only route) but I understand routing that antenna cable up through the tail is a non-trivial task.
Cool...How much does the departure from the horizontal plane effect efficiency?My intention was to show an alternative approach to the VOR/LOC/GS antenna installation for the RV-12. Thin wires bonded to the inside of the aft canopy is an easy installation. Routing the cable to the receiver is also easy compared to a wing tip or vertical stab installation. And the antenna performance is every bit as good as the conventional locations.
Well shoot fire, I learned something today.Do you recommend putting your wingtip antenna inside or outside the RV-12 metal wingtip?
Just thinking out-loud -- I can't think of a reason that you couldn't repurpose the "boomerang" VOR antenna from a Beech ABEFGV-33/35/36 and mounting it under the belly of the -12 in a suitable spot...
Or, use the Comant CI-120 "blades" up on the vertical stab ala Mooney.
Both of the aforementioned are available from the various aircraft salvage companies for much much less than new, and you get to give new life/purpose to something...
Cheers!
dont think the vertical fin structure would support blades without a lot of beefing up (rv12)
