Drilling Through Canopy Frame F-631A
avrojockey
Any issues with drilling a 1/2" hole through this tip-up frame for one of these Oplites then run the wire (shielded 22/3) on canopy?
Thought it would come in handy as instrument flood light and area light with canopy tipped up.
Tim,
I would not put there.
Use the brace right behind the cross over bar.
Easier to wire etc.
Boomer
Instead of drilling a large 1/2 " hole, create a separate mount and drill1/2" hole in it and screw your light in the mount. Then screw the mount to the frame using #6 screws so that you won't compromise the aircraft structure. Ot you can install nut plates and screw in the mount
Tim,
Easier to wire etc.
Boomer
The problem I'm foreseeing is with luggage. Pulling my heavy roller bag in/out I see it as a snag. If I mount to the canopy it doesn't become an issue.
Great idea
On the 14A I built, I installed a couple of round LED lights in the brace behind the bar, close to the front - lights up everything pretty well and doesn't block anything. Perhaps not as much light on panel but there I used red/white ribbon LED lights and they worked well
I put two Oplite lights on a z-bracket screwed into the rollbar brace. Power runs back through the brace and then up front to one of the G3X Touch dimmer control circuits. As Tim pointed out, they do sometimes get snagged by baggage/coats/etc but for me it was a good compromise as I wanted panel lights coming from that area. Blockage from backup canopy latch hasn't been a problem.
More at this link - https://mightyrv.com/?p=3825
HTH
Dave
I did that and am happy with the outcome. I used just regular 22 aviation wires and ran them through D profile rubber seals where the canopy meets the fuselage, on both sides.
Some caveats: afterwards i noticed that the D profiles are too thin, but they are a bit difficult to replace now due to wires running inside them. Also I would like to install a thicker D profile seal between the aft side of canopy and the roll bar, but the protruding wires from the lights make this somewhat more difficult.
I would do this again, but would plan better for sealing beforehand.
For those who are interested in my solution...
I found they make a flange mount for the map light I can rivet directly to F-631. Less compromising structurally than the 1/2" hole, and provides greater rigidity when adjusting the lamp. I'll have pictures of the install soon...
Followed your advice, but found this wire channel on Amazon where the top cover may be removed to access wire...
