howardtlcc
Our engine builder asked if we were running our prop cable under (Vans plan way) or over via the Showplanes bracket. We are using the PCU prop governor.
https://showplanes.com/Item/PC-
Is there a big advantage to the over routing?
If you go with the over route will the standard Vans prop cable still work (same length?)
thanks!
Howard
thanks!
Howard
