RVV-10 Tail Cone Wiring Access
dmjepsen
Good day all;
I am about to close-out the rear seat and baggage areas in my RV-10 fuselage. Before I do, I am trying to figure out how best to route all of the various cables, wires, and static tube from the tail cone to the side panels in the mid-cabin area. Suggestions?
Did you enlarge the two holes in the bottom left and right corners of F-1034A and F-1005A which were originally punched to 5/8" and if so, by how much?
PM me your email address and I’ll provide photos. I run three conduits on each side, use five and have one spare.
I did not enlarge any holes. All wire runs were through stock holes, but I did not run any conduit (however I do have messenger lines run in case I need to add a cable later on).
