Ballistic Parachute for the RV8
Hello, I am finishing the assembly of my RV-8 and I intend to perform acrobatics with it. It turns out that I am very tall 2.00 meters height and weight 100 kg (220 lbs), being tall limits the possibility of using a parachute on the back or even a seat because when gaining height in the seat my knees hit the instrument panel when commanding the rudder pedals.
Having explained all this, I decided to install a BRS parachute in the RV-8, analyze the efforts in the structure and carry out the installation of reinforcements, the calculation of the CG, etc.
This was the way I found to perform the acrobatics with a little more tranquility.
If you could share your experience installing these devices, I would like to know more, and how the RV-8 performs afterwards.
Below are the project photos.
Greetings,
That is quite the project you are considering. Butler Parachutes in the US has made “ lap “ type parachutes in the past. If you haven’t given up completely on the idea of a PEP, you might want to contact them and see if they can help you.
Good luck.
I like your project and I had the same problem with my RV8. If I had anyone in the rear seat I could only fly with 5 gallons of fuel if I wanted to stay in a legal W&B envelope.
I am experimenting with the BRS/WARPS idea
Granted, a chute pack would weigh more than a battery, but do not a lot of RV-8s opt for a rear mounted battery to bring C of G aft? Could not a fwd battery (with that mass now at an inverse arm) and a specific engine/prop combo make the rear seat usable at all?
I am modifying a RV-7 BRS kit for a RV-8A Fastback(Turtledeck remains clear and fuselage height for aft straps is similar) but there is a ways to go on this install. If you have info about of a flying RV-8 with this system, please post!
Yeah, I'm surprised to hear that about a rear-seat passenger. My impression has always been that the -8s tend to have issues with the CG being too far forward when solo. There are a couple threads floating around with people talking about ways to put easily-removable ballast back in the tail to make the plane fly better solo.
When I did the W&B for my RV8, it was near the rear CG datum at 1800# with full fuel and a big passenger, and full weight in the rear baggage compartment. As the fuel gets to minimum, the CG shifted past the rear datum by a few percent.
I have the light weight fixed pitch composite prop. But I think having a heavier constant speed prop will get a better balance at gross weight. There was a story posted here about a RV8 with passenger returning from Reno Air Race and the pilot experienced PIO when landing with a light fuel weight.
I've worked with several BRS and Second Chantz installs on light stuff. One aspect seldom considered is decapitation.
Given an airframe failure, there is no way to predict the attitude of the fuselage at deployment. Watch old BRS movies and you'll often see tumbling balls of junk. So, it's really helpful to have some structure around the cockpit in order to keep the bridle straps away from the pilot. If the canopy opens while a bridle is across the torso or neck...
Something like a Cirrus has an enclosed cockpit, here notable for its roof structure to keep the straps out.
Related, designers often try to arrange the rocket system so it fires aft and up and hangs upright. That's terrific if the assumed reason for deployment is an engine failure with the airframe gliding straight and level. It's entirely appropriate for a family airplane with a power failure in a bad place, and it sells well in the pictures. However, given an aerobatic airframe failure, it doesn't matter if the deployment is out the side or through the belly, because there is no way to predict "up". The only high probability is shooting more or less rearward, as even the balls of junk eventually tend to assume heavy end down.
Bottom line, you may want to re-think the 4-strap suspension, as it pulls the forward straps across the cockpit if there is any activity in the roll axis. Even if the strap does not reach the meat servo, a canopy collapse won't be pretty. A system with two aft straps doesn't guarantee no cockpit involvement, but it a lot less likely.
Have you successfully installed either BRS, Galaxy or Second Chantz on a RV-8? BRS routes the straps entirely outside the cabin on the 7 and 9 but they don’t have a system for the 8.
BRS told me this morning that they started an RV-8 project years ago and gave up. The person could not tell me why.
I am completing the installation of the parachute on my plane; these drawings I have attached are from the engineering project for the equipment installation. Once it's finished, I'll send it to you.
BRS softpack
The generic one? I tried to order the RV08SI-08 listed here and they said that they do not sell it.
https://brsaerospace.com/experimental-aircraft-catalog/?letter=V%
The engineering project for the installation of the ballistic parachute was not created by BRS, I'm only using their parachute, the project was designed here in Brazil by an aerospace engineering company, the same company that carried out the ballistic parachute project for the RV-10 that BRS sells.
The BRS ballistic project for the RV-10 was made by a Brazilian company, the same one that carried out the project for me for the RV-8.
Good luck with the parachute install!
Thanks for the offer; PM sent
Regarding bridle strap routing (and my plane is a bit different due Fastback), I'll share part of my modification in case you may want to consider something similar depending what chute deployment angles you predict.
I welded a nut on top of my aftermarket roll bar before powder coating and installing it a couple months ago. A bracket that engages with the nested canopy frame will be bolted to it. I expect a full width nested frame will increase my "safe" areas as well as help support the canopy in the event a strap is in a position to exert a side load (thankfully the angles required for that are near perpendicular to the strap ).
There are many on this forum better at engineering so as always, I welcome input!
Was it Flyer in Brazil?
Do you have more photos? I'd also like to see it finished and know the materials used to calculate if this will work correctly.
I liked your solution.
Good luck with your design and calculations
The roll bar is alloy steel that was TIG welded to the WD-808 seatback. As I am very tall, the roll bar was built as high as possible in addition to building the canopy high.
The rest was built from aluminum crops I had on hand. Perhaps with a standard '8 you have better options for mounting vs a moving composite structure like mine? With the tipover canopy and pre-existing components, there was a LOT of 3D geometry to make this all fit nicely so I just kept rebuilding it "in situ" until I got the fit that I was looking for.
The image is a bit distorted to capture the full view in the small space of the back seat. This assembly weighs way less than my GPS :eek: but should help mitigate a few more of the "what if" parachute deployment scenarios.
Once I finish avionics/electrical/servos/static line, I will final rivet on the turtledeck and then can return to BRS installation tasks but that will be a while...
