Disabling “Normalize” restores the data area and prevents spillover to Aux page (more important for 6cyl peeps).Just got mine loaded.
Only issue I had is my 6 CHT/EGT bumped my two Turbo Inlet Temps off to an AUX page instead of living right next to the CHT/EGT. Still playing to see if I can get that back.
Excited for Conditional Formatting.
Potentially reformat the Fuel Flow to have a narrower green band for Takeoff.
And a lower scale for correct ROP or LOP operation at reduced settings.
I've printed a bunch of manual pages but there looks like a lot of play time in the hangar coming up.
Appreciate the update!!
Tj
Also it appears you could easily overwrite your signal path number if you don’t keep things straight and select the correct path number.
I wish there was an AGL option for the supplemental conditional formatting which I assume is just MSL. I could trick it to ignore the gear warning horn above X agl for instance. Or a fuel pump ON or OFF around the 1000’ area.
Regardless, super new group of options.
Tom
