rgmiller1974
Hello Everyone,
I'm working on my panel and am at the point where I'd like to test the comm transmitters. I'm not too worried about the transmitters themselves, but I want to make sure the wiring is correct and I've got a good, clean signal from the microphone all the way to the transmitter.
AC 43.13 just says to test "...in accordance with the procedures appropriate for the airport and area..." That's not a lot of help. I'm not even at an airport; I'm still in my garage.
The best plan I can think of is to pick an unused frequency, connect the transmitter to a dummy load and then hold a hand-held receiver next to the dummy load. That said, dummy loads aren't perfect - which is why I think holding a handheld radio right near it will work - and that means I will be radiating some signal into the air.
So, my question is: Is there a better way to conduct this sort of test?
-Ross
-Ross
