Part ID help with Empennage
Mr.gator
I'm New Here
Can anyone tell me where this part goes; specifically the elbow. It came with the empennage kit and I believe it was included with the trim motor wiring. Since I’m done with this kit, I don’t want there to be an issue. Vans said they needed a part number, but this is all that I have. Thanks.
I think the only place for that elbow is the AHARS unit later on.
Which comes with three in the Avionics (or was it Finish?) kit. I think I might have gotten one of those as well, and just didn't use it. There are errors in the BOM for various kits, so it might just be an extra.
I have the same collection of 90 degree connector and 2 pieces of plastic tube left as well. (I'm almost done with the power plant - so I don't think they are used later.)
If you keep your packing list you can usually look up the bag identification on that list & figure out what the part number of the parts are.
(Assuming you don't separate the contents of the bags into individual part numbered containers).
Paul Fisher
RV 12 iS
That elbow is used on the low pressure side of the brake master cylinders. It may also be used elsewhere. Vans Part Number FLF-00007.
