Some background:
You can attach your trim motors to the GSA 28 autopilot servos such that they automatically adjust trim as they do their autopilot work. The servo has input and output pins for trim, so that manual trimming gets "passed through" the unit.
During the beginning of my flight testing, I had this automatic trim motor control function disabled in the G3X software (enabling/disabling it is described in the installation manual, 29.4.13.1&2). This was so that this automatic trim functionality would not interfere during my initial autopilot tuning. When this function is disabled, the autopilot will occasionally ask you to manually adjust the trim. This works fine.
The issue:
I recently decided to enable this automatic trim adjustment function, since I believe I have the AP servos' strengths dialed in and controlling both pitch and roll properly. Ever since then, I have noticed a problem with its command of roll trim. When in HDG mode, it will favor commanding RIGHT trim. It will occasionally trim left, but the vast majority of its trim commands are right. To the point where, if I let it go for a while, it will eventually end up with my roll trim actuator fully-right. Fortunately my RV's roll trim is that spring-bias system, which can be easily overpowered even at full trim deflection. Still, I question this behavior.
This does not happen when the AP is in "NAV" mode, following a track. Only when it is in "HDG" mode holding a particular heading. Pitch trim control is always fine. It trims up when it needs to and down when it needs to, and its behavior never results in full pitch trim deflection--only roll trim.
I've found that the problem is most often reproducible when I'm flying slowly (<90KIAS). Other than that, I have not done too much diagnosis to isolate what flight conditions cause it to happen.
Has anyone seen this kind of behavior and managed to correct it? Ray Allen roll trim servo, if that matters.
The issue:
