12iS B.U.D.S. Connection Issue
Bob Y
Friend
Note, this is an iS issue…. I’m trying to resolve why when I connect my Level 2 BUDS dongle to the data port, the software will not recognize the ECU. I first tried to download a friend’s data logs from his 12iS and BUDS couldn’t see the ECU. No recognition of the engine serial number and no Lane indicators - engine page never changed after powering up the ECU. LED on the dongle is solid when plugged into the USB pots and flashes when BUDS opens, just like it should. I’ve successfully used the dongle for over two years on mine and another friend’s 12iS. I always plug the dongle into an unpowered ECU after starting the software. Here are all the things I’ve tried:
  1. Tried two different 12iS aircraft
  2. Tried two different pcs
  3. Tried two different serial extension cables
  4. Tried BUDS v3.0 and v4.0
  5. Tried all three USB ports on the pc
  6. Verified there is voltage at the pins at the end of the extension cables
  7. Sent the dongle to Lockwood and it worked fine for them on pcs running Windows 10 & 11. Both of our pcs are running Windows 10, and ours and Lockwood’s are up-to-date on patches.
I’ve posted the issue to the Rotax Owners forum without anyone offering having experienced the same issue. I’m running out of ideas having exhausted all my substitutional troubleshooting options, except possibly one…
Have any of you 12iS guys had your ECU logs downloaded since replacing your HIC modules? It’s a stretch, but running out of common denominators. Anxious to hear what you guys say.
Thanks, but yes, I performed that SB and have successfully downloaded the logs since making the change. At the suggestion from one of the gurus on the Rotax Owners forum I connected the dongle directly to the maintenance port, but the same result. I even removed it from the avionics shelf to be sure I was getting a good connection.
So nobody has downloaded their ECU logs since the HIC replacement?
I also have the same issue - I took my iS to the local NZ Rotax agent last month to get them to do the annual on the engine, and they were unable to connect to the ECU via the mtce port with their buds software & dongle.
I removed the mtce port from the avionics shelf to rule out a bad pin connection (I just velcro it under the shelf now) but I am still getting the same issue and they can't connect to the ECU.
I do also have the new HIC module fitted, so not sure if this is the common denominator, but last time I had them plug in the dongle and download the data ok was when i had the old module installed - so you have me wondering now!!
Paul
#121263
Thank you! The HIC module is only supposed to tie the A and B CAN bus signals together and pass them through, I’m wondering if they might have gotten reversed in the new circuit? I’m heading back to the hangar this morning and will reverse the pins and report back. And I too disconnected my serial port from the avionics shelf to make sure I was getting a solid connection, with no improvement. Anxious to see what I learn. Stand by…
Success!!!! The HI and LOW connections in the new HIC are reversed! So, us iS owners appear to have another SB coming our way.
And for anyone with an iS that has paid an A&P to perform a 100 interval Rotax engine inspection since replacing the HIC module, I’d suggest looking at the Rotax check list to see if the task for downloading the ECU logs is checked off.
I’ll notify Van’s Support of the issue.
I'm sorry to inform everyone, but the Rotax Maintenance Port (CAN bus) wiring was changed on the AV-60009-2 HIC Module. This latest HIC PCB was designed using the original (correct) HIC design plans. The problem is, the previous HIC PCB had pins 14 and 15 (Maint. CAN Bus HI & Low) reversed. That was the reason for SL-00009.
The updated wiring schematic and associated Service Letter have yet to be released, I expect it will be released soon.
If you cannot get the BUDS dongle to connect to the ECU, you can swap the CAN Bus wires at the easy-to-access 9-pin Maintenance Port connector instead of messing with them in the 25-pin HIC connector, for ease of access.
As always Tony, you have excellent knowledge! :) Thank you, thank you, thank you! From both me and Frank.
BTW, I saw your plane at OSH last year… beautiful job putting it together.
Just working through this today, can confirm swapping pin 2 and 7 on the DSUB9 maintenance port is what allowed the Rotax BUDS system to connect.
Fly safe!
-Jim
RV-12iS
Yep, I asked if I needed to do SL-0009 before changing to new HIC upgrade.
No, but my Rotax B.U.D.S system does not work now. Grin
Yep the short cut is with the confirmed swapping pin 2 and 7 on the DSUB9 maintenance port is what allowed the Rotax BUDS system to connect. Grin
RV-12iS
How exactly does one do this? Do I go in through the PFD or MFD? Anyone with some pictures of what I need to do here? I am trying to get this fixed so my mechanic can connect his BUDS dongle but I didn't build the aircraft so it's all new to me. I'm looking at the Section 42MiS/U: Common Electrical diagram on page 13 but I'm confused on where exactly this swapping of wires needs to occur or how to access it. I bought a DSUB pin removal/insertion device so I've got what I need to swap the pins.
The Maintenance Port is a 9-pin DB connector attached to the right side of the F-01202B-1 panel. You can access it by removing the right screen or the right instrument panel if you have a single screen.
If your BUDS dongle won't connect just swap the two wires in this connector.
Thanks Tony! Gonna give this a shot this week and report back once the mechanic plugs into it.
Found this on youtube, is this the port you are referring to? The video makes it look like there's only 1 wire but I'm assuming there is 2 and they need to be swapped?
Yes, that’s it. There are two wires in the bundle. Just swap the pins as Tony indicated.
Looking at your photo above, it appers that the two wires are in pins 2 and 7. The pins that I am working with appear to have come from the factory in pins 1 and 2, resulting in no connection (see attached photo). Can anyone confirm that pins 2 and 7 are the correct setup?
You are correct. The white wire is in the correct spot (pin 2) but the white/blue wire should be in pin 7. DM me if you need an extraction tool for your D-Sub.
Thank you for your help. The wires were indeed in the wrong location from the factory. They have been put in the correct pin locations and connection to the ECU was successful.
