I'm anxious to hear the reply as I just had this done. I was under the impression that we just followed Van's instructions when putting the wheel back on. On the RV-14 mains Van's states to,
"Rotate each Main Wheel and Tire Assembly while hand-tightening the corresponding axle nut until there is no side play in the wheel and the wheel rotates with little or no friction."
I didn't see a spacer in between the two bearings on the main gear for my -7. They were done about 3-4 months ago. Looked up the bearing number (Spinco CSA 206-20) and see it has some sort of a locking collar but actually looks like a flange is resting on the surface of the original wheel halves that they machine to fit the bearing. A very good idea but I certainly don't see a spacer inside. There are certainly two spacers that ride on the axle on the outside of the wheel, but not the inside so I can only assume it is the strength of the wheels themselves that hold the bearings in position. I'm trying to figure out how much pre-load I can put on the big axle nut so that the brake flange bolt can be snugged up to prevent the brakes/wheel fairing from wiggling back and forth. Recommendations?yes
Yes, there is a machined spacer in the middle.
To clarify, the nose wheel mod has the spacer. The mains do not have a spacer and instead, the bearings are stopped by a .030" step in the bore according to anti splat.I didn't see a spacer in between the two bearings on the main gear for my -7. They were done about 3-4 months ago. Looked up the bearing number (Spinco CSA 206-20) and see it has some sort of a locking collar but actually looks like a flange is resting on the surface of the original wheel halves that they machine to fit the bearing. A very good idea but I certainly don't see a spacer inside. There are certainly two spacers that ride on the axle on the outside of the wheel, but not the inside so I can only assume it is the strength of the wheels themselves that hold the bearings in position. I'm trying to figure out how much pre-load I can put on the big axle nut so that the brake flange bolt can be snugged up to prevent the brakes/wheel fairing from wiggling back and forth. Recommendations?
Yes, on the mains, one cotter pin went in perfectly and the other would have allowed a bit of slop therefore I added the McMaster shim.ASA told me 25 ft lbs on the nose wheel bolt.
For the mains, snug them up, then back off to fit cotter pin. (As mentioned above).
Cheers
Stephen
