I have been trying to figure out the Lean Assist on my G3X. I can get all the cylinders in the blue but the temps are not even - up to 30 degrees or so different. Im all for leaning the mixture but not really sure what temp I am going for. Questions:
1. How close to the same temp should all the cylinders be?
2. What temp should it be and what is the max - temp?
3. I know from watching Mike and Vic videos that there is a place you dont want to be. What is that place?
I have an O-320 D2A with 160 hp, fixed pitch Catto, and a carb. Use 100ll.
Thanks for the help. I will check out other videos and see what I can figure out.
