I was playing around with methods to raise the nose wheel with the tail tie down eye bolt. Easy peasy
But my “oh no” moment came when I went to the nose wheel checking how high it was off the ground, that’s when I noticed about 1/4” play in the vertical axis.
Seems to be pivoting at the mount of the strut to the frame.
Before I pull off cowlings and do a bunch of investigation, I wanted to ask those experienced here if any vertical play is normal/acceptable?
How much of a concern is this ? Difficult repair (if needed) ? Tighten a bolt or replace a rubber mount ?
She tracks perfect down the RW, no shimmy ( but that would be from horizon play or tire issues) or any other noticeable handling issue.
