Ok, got my -6 equipped with the -8 tail inspected today.
Enlarged the tooling hole with a long 8mm drill bit... using full up deflection barely cleared the elevator counterweight.
Used the newly acquired borescope from our association, a Teslong Td500 which worked perfectly. The hammered rivet heads are logically on the hinge brackets and no cracks on this 1'500h, with some mild aeros, year 2000 kit machine
