Why not install Tire Pressure Monitors instead? I've been using TPM on main tires for over a year. Tire pressure can be checked as part of preflight inspection. Works a charm....
https://vansairforce.net/community/showthread.php?t=199694&highlight=tpm
Photos are TPM and stick-on balance weight...
I can't unscrew it and add air without removing the front pant
Would "flow-through" monitors work for us? Like these?
I have a hangar-mate with a Zenith 750 Cruzer so I'm considering this kit, 3 for my -12iS and 3 for his 750 Cruzer. We could keep the monitor unit on the workbench and check both aircraft at the same time!
Too big and bulky. Might be difficult to balance wheel. Get similar unit as my post above and Bluetooth to cell phone app...
I have these on my main tires and they work perfectly.
Did you put one on the nose gear tire ?
I did'nt.
Max
Has anyone put a sensor on nose gear?
Can you take it off and add air with removing the wheel pant?
I’m surprised that something like the oil filler door hasn’t been done more often like Cessna’s had. Seems easy enough to do.
Cessna can't even make pilot / passenger ingress doors so they stay shut....
Flying my airplane without wheel pants costs me about 10 knots at cruise.I ditched my wheel pants after a couple of years. It was too much hassle to add air. If the tire goes flat the weight goes on to the wheel pants and you have to jack up the plane to fill the tire. They look great, but not really practical.
All of the "screw on" valve cap types do. In fact, the Fobo Brand that I used introduced a slow leak -- either I "forgot" to lube an o-ring (I hate when that happens) or the little transducer leaked. Either way, I decided it wasn't worth it.Don’t some of the tire pressure monitors depress the Schrader valve stem when installed? Not sure I want to give up on having that valve.
I appreciate this post....the slider gauge on 12 year-old inflator that the OB included with the airplane has become suspect.Resurrecting this old thread because Cleveland tool now has their Valve stem inflator tool in stock!
https://cleavelandtool.com/products/cleaveland-valve-stem-inflation-tool?_pos=1&_sid=48a87e8df&_ss=r
That (or very similar) is the one I have, but with a straight chuck (OB had to grind off the angled part so that the hole in the wheel pants would be smaller). I started getting "notchiness" in the pressure slider and the pressures I was getting weren't repeatable. I tried some silicone spray, which improves things only for awhile. The dial is easier to read, but no doubt will turn out to be more fragile.Was it one of these? https://steelmantools.com/products/straight-chuck-tire-inflator-12-inch-red-hose
They seem quite robust, but I've never tried to calibrate it with another gauge.
--Ron
Where does one find no leak tubes? I can't seem to find any tubes that hold pressure for more than a few weeks.I looked at cutting holes in my pants and even bought some nice streamline covers for the holes, Never could bring myself to cut holes in the pants.
Instead... buy some no leak tubes they hold pressure for almost 12 months depending on OATs, then get some bluetooth pressure sending valve caps from FOBO and read the pressure on your cell phone, even during flight, with a warning if it drops below a certain value. I've had this arrangement for almost 4 years and never had to pull the pants to add air more than a couple of times between Cnd Instp. Only have to replace valve stem battery evey 2 years or so when the cell phone ap says it's low, I alway do them early, usually during CI.
Michelin air stop tubes.. they have to be the Michelin ones. Goodyear are ok too, but the Michelin are the best. Unfortunately they don’t make a nosewheel tube. The best solution is to build a tailwheel!!Where does one find no leak tubes? I can't seem to find any tubes that hold pressure for more than a few weeks.
Reminds me of an ad I once saw; "When one door closes, another one opens. Other than that, it's pretty good Cessna."
Bet this guy wouldn't agree, he stopped by just a few days ago to discuss what to do with his damaged bird.The best solution is to build a tailwheel!!
No laughing here! That looks GREAT!Poke fun all you want to but it sure makes it easy to reach inside to unscrew the cap and check the pressure. I made the door first and the used it as a pattern to cut out the pants.
I bought one of those from Cleaveland when they started selling them. I shortly thereafter was notified that if line pressure was greater than 60 psi, the gauge might be destroyed. Did they address that in the later versions, or does that warning still apply?Cleaveland had a nice straight chucker at OSH
This is why the Cleveland tool is a little bit unique, it does not have the angled foot.I got one of the straight extensions but found that the angled valve stem won't line up with the wheel pant hole. It's Grove brakes & wheels, maybe Matcos line up. I wish I'd added the doors that Webb describes.
I find this works well : https://www.aircraftspruce.com/catalog/lgpages/ae06-03064.php?clickkey=2781314
What you've referenced is a solid metal tube, but the extension I've provided a link to is flexible, making it much easier to connect and tighten on a Schrader valve.So that's basically the equivalent of what you can get on Amazon. A pair of them for under $15.
I used them for a little while. Compared to the Cleveland too it's kind of a pain with the threading, then attaching a gauge and chuck or each separately, and then keep track of the extension separately from your air chuck. With the Cleveland chuck tool it's one tool and one push-on action.
Marginal difference. Extensions will get the job done but it's so much more convenient with the tool.
