Rallylancer122
Replaced my dead sl40 witha GTR200B. Wired as Com2 to a PMA4000 audio panel. Per the Garmin manual I used the "Reciever Audio Out" pins to feed audio to the PMA4000. However the only way to get the audio to come through was disable the intercom function in the config. This also apparently disables Bluetooth, which I paid an extra $150 to get and would really like to use.
Is there a workaround for this?
I'm thinking I can wire to the "Pilot Headset" pins instead and then enable the intercom, but wanted to see if there was another solution before I broke out the pin extractor and performed surgery.
