I had the same problem with my
Rv10 elevator trim. I was staring at the plans for several hours. Though my one cable was too far down because it didn’t match the plans. When I read about the cables being in neutral position with a shadow of the positions on arm …. It all makes sense. Sometimes we overthink things.
The instructions here are very poor and if you follow them, you may end up with the two tabs in an assymetric condition at neutral. Tim has a good set of instructions on his site for setting it up a different way that leaves the two tabs perfectly aligned at neutral. Suggest reviewing it.
Could you please add a link or name of the build log site?
Thanks!
I was wondering what is the best type of wire to run my RA actuator servo elevator trim to the panel…. I heard it’s not too big of deal and was going to run thermostat 5 conductor wire 20 or 22awg stranded?? Thoughts anyone. Does shielding become mandatory here? And can the black wire be grounded to a AN3 bolt near the aft?
Thanks all
