If your battery is on the firewall, make sure nothing blocks it from sliding out of the box.
Drilling the firewall is a pain. Take advantage of predrilled rivet holes where ever possible.
Here's what I did after calling VP. They said the PPS was designed to fit where the OEM contactors, etc are attached. So, I fabbed an assembly. It mounts to the four nut plates on the firewall intended for the contactors. No drilling required. I just hope it doesn't interfere with anything coming next.
Where does the oil cooler get mounted?
Lower right side.
Hi rockitdoc, I am also building 14A and was wondering if we have recent pictures of your build. I am particularly interested in seeing if the PPS was in the way of any other firewall forward components, as I am planing to install it on the same location as you did.
Appreciate any feedback.
Thanks!
Thanks!
PPS mounted using aluminum plate milled to fit.
I did use a milling machine to make it, but if you don't have access to one, there are plenty of places, including online sites, that would make it for you. Simple design. I didn't weigh it, but it is fairly light. Made from 2024-T3. I have a cad drawing in PDF I could share with you if you'd like. Be tomorrow before I can get it sent off.Did you CNC that mount? I'm doing a 14, as well, and suspect that would work for me but I'm not a machinist by any stretch. What does the mount weigh?
This is how I mounted a PPS in my RV14. I positioned it far enough left to miss the oil breather tube. See …
Seems to be a robust method, no problems yet after 30 hrs.
