Carb Balance tube source
cactusman
Would help if i used the right terminology. Amazing that i could actually survive 20,000 hrs and 3 turbine engine failures and yet still i fight my dyslexic reading tendencies daily....
Changelog
02/11/2022
RV-12 MM Section 7 REV 3: Added note to ‘CAUTION’ statement to add MIL-PRF-83282 to approved brake fluids.
RV-12 MM Section 12 Rev 7: Added Throttle Return Spring Retainer callout to Figure 28. Removed instruction to disconnect throttle spring during idle adjustment.
RV-12 MM page 18-5 Rev 11: Manifold Pressure Hose; 5 years was 10 years.
RV-12 MM page 18-5 Rev 11: Added “Oil Vent Interconnect Hose; Replace; 5 Years; (pp) 12-16
With E-SLA, you have freedom to use whatever hose you'd like. I replaced coolant and vacuum hoses with High-Performance Silicone Heater Hose. As I recall the hose for the intake manifold crossover was an odd size. Photos show thick wall hose used for this application. I sourced from HPS. Below is spec for tubing used for crossover and for coolant overflow tank...
HPS 1/4" ID Blue High Temp Reinforced Silicone Heater Hose Tubing, 6mm
HPS 7/16" ID, 1 Foot Length, Silicone Straight Coupler Tube Hose, High Temp 4-ply Reinforced, Blue, 11mm ID
