I purchased a partially completed 14A empennage from a builder who used AZKO primer. He had primed all of the vertical and horizontal stabilizer, rudder, and elevator components, but had not started on any of the tail cone parts.
I have spent a lot of time reading the forum and evaluating the pros and cons of priming and which products to consider. I have decided to prime and have settled on SW P60G2/R7K44. I can source from a local SW Industrial Store at a reasonable price. I also plan to use the 3M PPS system.
If you are using this product and spray system, would you be kind enough to share you experience with the following:
1: Which nozzle do you use? (needle size if you don't use the 3M PPS)
2: What is your reducer ratio? 1:1.5 is recommended, but I see some are getting better results with 1:2.
