Fuel hose between my gascolator and fuel pump sprung a leak. Time to change all the hoses, they must be 25 years old, although only 650 hrs of run. The failed hose took a 90 degree bend in a 11" of length end to end, failed in the bend somewhere.
Same hoses and fittings are used for fuel and oil cooler. Hose was stainless braided, with an inner rubber hose with I guess nylon braid or something similar. The fittings are all Earls, see pic.
Looking at spruce, I decided aeroquip was the way to go, reading the aeroquip hose catalog I landed on 601 as the proper hose. Of course this means I need new fittings, and the correct ones are $$.
Guys at the airport say "summit racing" sells aeroquip, same part numbers as spruce, but cheaper. I go to summits website, I don't see 601 hose or the fittings for it. I do see AQP hose which seems similar to 601, maybe just not "certified for AC"? Still, their AQP fittings don't look like the 601 fittings.
Can (should) I reuse the Earls fittings? If so what kind of hose?
This is getting long winded. Sorry.
I know what you guys are going to say...call aircraft specialtiy. And I am not against that, but want to know what I can assemble myself. They don't say what they are using, as in a brand, which makes me wonder. If not brand then tell me what specification it meets, MS or whatever, I have access to all that stuff.
