Dozer Member Mar 12, 2022 #1 Hi. Any ideas, what type of resin do Vans use to produce fiberglass parts for a rudder, wingtips, etc. ?
pazmanyflyer Well Known Member Mar 12, 2022 #2 West System Epoxy. You can get it at West Marine if you have one local.
Dozer Member Mar 12, 2022 #3 pazmanyflyer said: West System Epoxy. You can get it at West Marine if you have one local. Click to expand... Sure?, because if they use any Polyester resin, blue system is not compatible (because it's epoxy)
wirejock Well Known Member Patron Mar 12, 2022 #4 Fiberglass Dozer said: Hi. Any ideas, what type of resin do Vans use to produce fiberglass parts for a rudder, wingtips, etc. ? Click to expand... It's all epoxy fiberglass. Everyone uses epoxy. Usually West Systems.
gyoung Well Known Member Mar 12, 2022 #5 Dozer said: Sure?, because if they use any Polyester resin, blue system is not compatible (because it's epoxy) Click to expand... It's the other way... you can put epoxy on a polyester part but not polyester on an epoxy part. I use West Systems on everything.
pazmanyflyer Well Known Member Mar 12, 2022 #6 Dozer said: Sure?, because if they use any Polyester resin, blue system is not compatible (because it's epoxy) Click to expand... Yes I am. See 1.14 seconds into video. Vans prototype builder Scott McDaniel using West System. https://m.youtube.com/watch?v=pn9FMtOCS7U
