My battery is in the back of my 8, behind the baggage compartment.
IO 360 is slow to crank, and tends to stall at TDC.
Battery holds 13v, but drops to 9v when I crank, right at the terminals. No voltage drop from the battery to the starter. From what I've read, I need a minimum of 10v to properly spin this skytec lightweight starter and RV200 prop.
I did get this battery on Amazon. Before I go buy another, is there something the same size and weight that puts out more CCA? Not concerned about saving money, looking for the most output in that size and weight range.
