162 KTS on 10 GPM
bryanflood
Hello all,
I have read a few posts saying that 160 kts at 10 GPM is not possible for an RV-10. I just want to report my experience on the RV-10 performance. My RV-10 is not particularly fast, in fact I think it is a couple kts short of Van's numbers, so I would expect other RV-10's to be better.
I have verified the true air speed with 4 ways GPS runs and find that it is within 1-2 kts. The fuel flow gauge usually reports about .7-.8 GPM high on fuel use compared to the pump at the end of a flight. So I believe the fuel flow is accurate and reads conservatively if anything.
Here is a picture of 162 KTS true airspeed at 10 GPM. The flight conditions are 8000 foot density altitude, just under 60% power, lean of peak EGT and 2100 RPM.
https://photos.app.goo.gl/6Armhx9jDECRatYQA
The RV-10 really is an efficient machine.
Bryan
Beautiful panel! You know that you can adjust your fuel flow to be dead on accurate by adjusting your K factor..
RPMs?
In my experience it will run a bit faster on the same fuel flow at 2300 rpms.
I generally set for just under 170ts and a touch under 11gph LOP.
My 10 is happiest and fastest between 9000 and 11,000 feet
Hello all,
Bryan
Bryan, what propeller are you using? And what was the gross weight when you did this test?
Test weight
1001001,
The prop is a Hartzell C2YR-1BFP/F8068D, van's standard offering. Test weight was 2300 lbs with a CG of about 25% of full range from forward.
I didn't think anyone would be too interested in going slow, but the RV-10 can do even better if you continue to slow down. For example at 7.6 GPM, 45% PWR, 1900 RPM and DA 1900 ft, I see 146 kts true = 19.21 NM/gal no wind. A very efficient way to operate for sure. I'm guessing people don't often fly like this, but interesting to know you can. A pretty stunning fuel savings over a more typical burn I see reported for RV-10's operating ROP at 160 kts and around 12GPM = 13.3 NM/gal
Thanks all for sharing performance points.
Bryan
Hello all,
Bryan
Bryan, what kind of ignition and fuel injection system are you using?
1001001,
Bryan
Thanks for the update. I'm planning on an MT prop--most reports I've seen/heard don't seem to support the "3 blades are slower than 2" trope, so I hope that's the case.
Fast cruise, low burn, LOP
It can definitely be done.
