Craw
Gooday Folks,
I would like to provide backup power to a TailbeaconX ADSB. I have the AV20E and the Tailbeacon powered via the same terminal block. My concern is that adding a BU battery feed from the IBBS system to the same terminal block could cause some issues:
1. Whats to stop the power from being sourced from the IBBS in normal operations?
2. Would a Diode be enough to prevent the regular power feed from the VP-X to the terminal block from interfering with the IBBS feed?
My logic here is that if the I ever have to rely on the IBBS system it wouldnt support a radio for more than 30 seconds so why not just sqawk 7700 and put down somewhere as quickly as possible.
Is there anyway to accomplish this?
Thanks much,
Thanks much,
