Hey Mel -
Is it true that the classification at first Airworthiness is the only one that can ever be? Meaning, it's either S-LSA or E-LSA forever.
There's a conversation on some other forum about this, and I thought there was only one chance to select.
Thanks.
If it is EAB, it's forever. If it's ELSA, it's forever. If it's SLSA it may be changed to ELSA.
That?s actually not true. If you can get the manufacturer (Van?s) to do a full conformity inspection, and the aircraft hasn?t been changed in any way so that it does actually conform, then a new SLSA airworthiness certificate can be issued. Just not very practical.And if SLSA is changed to ELSA it is forever - no going back...
When I asked one owner of a RV12 about the Operating Limitations, he said there were none. Is that possible?
The only reason I would prefer E-LSA as a buyer is the ability to get the repairman certificate and sign off on the condition inspection. Of course an E-AB RV-12 was most likely not built strictly to plans (why else would you make it E-AB?), but one would hope that any deviations would be discovered and discussed during the prebuy inspection. No matter what the airworthiness certificate says, just like any other airplane you really need to know exactly what you're buying -- or be willing to deal with the inevitable surprises.Another point for a buyer, if you feel that the ELSA is "better" because it was built strictly according to a standard, think again. The day AFTER the ELSA certificate, most any changes you might dream up are perfectly legal and do not have to be in accordance with the ELSA requirements. If you like your lawnmower engine, you can now fly behind your lawnmower engine. After all, it is EXPERIMENTAL!
The possibility here is that the builder may already have an engine, prop, avionics, etc., and prefer to use those instead of buying new from the kit manufacturer.
Correct me if I'm wrong, but I'm under the impression that a pilot with a Light Sport license and a "Driver's License medical" is legal to fly an E-LSA certificated airplane but not an E-AB, since an E-AB requires at least a Private Pilot license and 3rd Class Medical.
I'd think that this could be a reason to choose E-LSA over EAB registration.
Starting to build an RV-12iS and I think I may certify as E-AB just incase I want to install the IFR package and fly on an actual IMC path. Not sure what advantage certifying as E-LSA provides.
Yep. Theoretically possible, probably not ever actually done.
Nothing prohibits you from flying an E-LSA in IMC. You are not bound by the language in the POH/AFM.. only the language in your Airworthiness Certificate. (S-LSA is a different story). However, you "should" have more than just the IFR package installed (heated pitot, alternate air, a second ADAHARS unit, etc).
I am curious as to what limitations a DAR has on writing operating limits in the Airworthiness Certificate for an E-LSA.
Supposedly he is inspecting something that was built as an ASTM conforming item (the S-LSA), and the ASTM specifically prohibits IMC operation. Can a DAR make whatever non-conforming modifications to the S-LSA limitations they want in writing the AW certificate? Is there any reason they could not also increase the gross weight or airspeed limitations as an example?
The presumption here is the POH, which is part of the conforming item presented for inspection, does not apply to the limitations written in the AW certificate.
Opening limits aren’t issued randomly, there issued under the guidance of FAA order 8130.2J. If you want to see the differences between S-LSA, E-LSA and E-AB download a copy https://www.faa.gov/documentlibrary/media/order/faa_order_8130.2j.pdf
have a look at appendix D and build yourself a set of each.
It’s not the DAR, it’s the FAA that allows IFR/IMC operations though the opening limits. The airspace we fly is the FAAs domain, ASTM has no jurisdiction
Look at the op-limits, compliance to operations dictated in the Manufacture supplied POH only applies to an S-LSA. If your an E-LSA add the required equipment and modify the page after certification, after all you are experimental
An E-LSA only needs to match its S-LSA duplicate at the time of certification. Once certified you can modify it all you want as long as you keep it within the definition of an LSA (FAR section 1.1) and follow your op-limits
And herein lies the confusion.
Can you modify your ELSA after certification? Yes
Can you modify your ELSA to the point it no longer meets the definition of being an LSA? No (it would be nice, wouldn’t it?)
What defines the certification requirements for an ELSA? ASTM 2245-20
What does ASTM 2245-20 say about VFR/IFR? Limited to VFR flight only.
When you build your ELSA, you’ll placard it to say flight in IMC prohibited. Can you peel that off after certification and go fly in IMC? Sure you can. Will anyone question you or care? Probably not… unless you are involved in a mishap. Then I’m sure your insurance company will turn away from you in a heartbeat and the FAA will question why you flew an aircraft in IMC that wasn’t certificated to do so.
That the aircraft is “experimental” is moot. It’s not an EAB, it’s an LSA.
But hey folks, it’s your license. What’s it worth to you?
I personally don’t care if you build E-AB or E-LSA. My point is that you will get the exact same operating limits for IFR/IMC operation either way it’s licensed.
Look a FAR 21.191. There are nine sub groups for “Experimental” certification, including both E-AB and E-LSA. LSA is one path into certification. Both E-AB and E-LSA get specific benefits/penalties for being “experimental” But for IFR operation they are treated equally.
I tried to re-read this thread to make sure I had all the rules down pat......but then decided to do something less confusing.... like drinking a fifth of Jack Daniels and unscrambling a Rubik's Cube while strapped to an inversion table.....
This is most certainly the quintessence of FAA rulemaking .....
There seems to be some confusion with the terms LSA and E-LSA.
LSA describes the characteristics of an aircraft as defined by our government. LSA has nothing to do with aircraft registration.
There is no aircraft registration category called LSA, just as there are no aircraft registration categories called high-wing or tail-dragger.
Many type certificated aircraft are LSA.
Homebuilt aircraft can be registered as E-AB or E-LSA and other ways.
Both E-AB and E-LSA are Experimental. If someone says that they are going to register their aircraft as experimental,
they need to be more specific. Do they mean E-AB or E-LSA or E-Exhibition or what?
21. Kinds of operations authorized:
Day VFR flight operations are authorized. (47)
22. Night flight operations are authorized if the instruments specified in § 91.205(c) are installed, operational, and maintained per the applicable
requirements of part 91. (48)
23. Instrument flight operations are authorized if the instruments specified in § 91.205(d) are installed, operational, compliant with the performance
requirements of, and maintained per the applicable regulations. All maintenance or inspection of this equipment must be recorded in the aircraft
maintenance records and include the following items: date, work performed, and name and certificate number of person returning aircraft to service.
This aircraft may only be operated per the manufacturer’s aircraft
operating instructions (AOI), including any requirement for necessary
operating equipment specified in the aircraft’s equipment list. Night flight
and instrument flight rules (IFR) operations are authorized if allowed by
the AOI and if the instruments specified in § 91.205 are installed,
operational, and maintained per the applicable requirements of part 91.
(6)
Here are the actual conditions on my E-LSA AW certificate. This is the same language as used for E-AB and S-LSA.
However, S-LSA also get:
Paragraphs 22 & 23 that you quote are used in Op Lims for E-AB and E-LSA.
If these 2 paragraphs are found in Op Lims for S-LSA, they were issued in error.
Go to FAA Order 8130.2J Appendix D and you will find that these 2 paragraphs are issued to aircraft certificated under 21.191 and 21.191(b), (f), (g). (h), & (i) respectively.
Builder's choice. To qualify as ELSA the aircraft must be built exactly per plans and all parts must be purchased from the kit manufacturer.
Some people prefer to make minor or major modifications during the build. Or in some cases they may already have an engine or avionics and prefer to install these as opposed to ordering new from Vans. The builder my opt for EAB so that he/she doesn't have to go to class to obtain the repairman certificate. EAB can be modified to take it out of the Light-Sport parameters. ELSA cannot. There can be a multitude of reasons.
EAB is not necessarily better or worse than ELSA. Just different.
In other words... does it have to meet spec or does it have to be purchased thru kit manufacturer?
Thanks for any information you can offer.
The answer is yes to both questions.
Meeting the second requirement automatically assures it meets the first one.
Van's has to supply an ELSA builder with a form (Form 8130-15) certifying that the airplane kit was delivered able to be built as an exact copy of our SLSA aircraft. The able part is because it is then the builders responsibility to build it that way, and they have to sign the same form at certification certifying that they did so.
Van's is burdened with assuring that happens, and to help assure that, the FAA requires Van's to supply all components in order to sign the form certifying it as an ELSA kit.
