Anyone using this MATCO wheel and three piston brake? If so, any observations?
http://www.matcomfg.com/WHLBRKWI600RV10CONFIG-idv-3814-4.html
Thanks Bob, but what size tire? The stock 15x6.00-6 or a standard 6.00x6?
What size tire are you using?
I will be using the James Aircraft wheel pant on this RV-10 build like I did the first. They have a significantly smaller frontal cross section compared to the very wide stock pants. I would be interested in any tolerance issue you may have had between this brake assembly and your wheel pants.
I know I’m beating a dead horse here, but you might want to set aside some additional funds to replace the cheap Chinese bearings provided by Matco with some decent ones made by Timken or a reputable manufacturer.
Don’t know what Anti-splat installs with their bearing mod.
George Happ is usually very helpful, but his less than satisfactory response to the substitution of Timken bearings with some Chinese no-name has left me lacking and quite disappointed with Matco.
I'm looking at putting together my finish kit order in the next few days...with the Matco wheels and 3-piston brakes, is a different tire required? Should I just delete all tire/wheel/brake items from the finish kit and buy from Matco directly?
I ordered the Matco system and have not yet installed it. You can use the standard tires that come with the Vans kit. I am going to use the Wilkerson retreads just because apparently the retreads are slightly larger diameter and last longer. I deleted the Vans tubes as well as I wanted the 90degree stems.
Keith
Did you buy the wheels and brakes (including nosewheel) from Matco directly?
