Aerosport and baggage door locks
Weefle
I will be installing the flush door handles from Aerosport and am wondering what others have used for a lock. I was at the local locksmith today trying to fit a lock to my baggage door and even that’s a **** shoot. Ideally I’d like to have a single key to fit all three locks. Any suggestions, vendors, part numbers appreciated?
Keith
If you're willing to spend a little more, Medeco locks can be sold as a keyed alike set through Aircraft Security (Texas). They're high security locks, but about $330 for all three as a set.
I was able to get ACS to provide me with the ignition switch and 3 door locks all three keyed the same. Admittedly these locks will only prevent entry from the curious.
I used camlocks. Super durable, however a bit of a chore to install. If I had to do over I would just use an ACS set.
Northeast Lock
At the suggestion of Will at Aerosport I used a set from Northeast Lock and they have worked fine. At only $12 each! Looks like the website is under construction but give then a call.
https://northeastlock.com/
DC622S-KA-200R 5/8" DUST SHUTTER CAM LOCK, 90 2KP, KA #200R
Cheers
Mark Easton
Cheers
Mark Easton
Does this lock also fit the baggage door as well or only the Aerosport handles? I.E. a matching set for the handles and baggage door?
I also went through this ordeal, but decided on a different option. Aerosport has a trim ring that doesn't have the hole for the door lock.
I have decided not to lock my plane. If a thief really wants that 650 or the Bose headsets, they will just break a window or pry the door open. We had this happen to a Bonanza shop nearby. They broke into several planes using a crowbar :eek: I have insurance.... and after all the work it was to fit the doors and windows, I'd really rather not go through that again!
