If I were to install either of these connectors, would I need a special crimper or would my standard Dsub crimper work?
Thanks!
Dave
Thanks!
Dave
I think the Deutsch connectors use a different crimper, especially for the larger pins/sockets...
I bought an AF8 crimper with turret head on eBay. It does the three common pin/socket sizes...
I too have both a AFM8 and AF8. I was looking at replacing some of my outside connectors with DT or DTM connectors.
I have one torrent for the AF8 which is for coax pins if my memory is correct, so what torrent do I need for DT or DTM pins with the AF8?
Thanks.
Brian
yes . indeed!Thanks for the info, just wanted to check, is this the crimper you're talking about?
https://www.amazon.com/JRready-M225...t=&hvlocphy=1013962&hvtargid=pla-898381839290
TIA
Still looking for answer. What I would like to get is a turret for the DT and DTM pins. Which one do I need?
I just got home, and checked the ones I have, which is a TH4, and TH285 which is for coax center pins. Neither one of those will work.
Thanks for your help.
Brian
yes . indeed!
I did my DTM with some cheap crimpers. similar to DSUB. 8 years and they have been perfect. I like the gold plated DTM pins and sockets, no corrosion. I purchased the crimpers from Amazon. 4 quadrant smash. I'll look for the model of mine if you still need it. $30 or so.
here you go...
https://www.amazon.com/IWISS-Crimper-Impression-Deutsch-Contacts/dp/B07V1C6N2V/ref=sr_1_2_sspa?dchild=1&keywords=dtm+crimper&qid=1630291209&s=hi&sr=1-2-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUFVNkNWRUhTNE1TWDQmZW5jcnlwdGVkSWQ9QTA3NDQ2NTczS0xSNTZLVUtEODhIJmVuY3J5cHRlZEFkSWQ9QTA3NzY1NzIzUDdJM0dKV1JONVIyJndpZGdldE5hbWU9c3BfYXRmJmFjdGlvbj1jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ==
https://www.amazon.com/Ratchet-Crimping-Tool-Terminal-Connectors/dp/B08HYVJPHT/ref=sr_1_7?dchild=1&keywords=dtm+crimper&qid=1630291209&s=hi&sr=1-7
