I'm trying to get my landing gear mounts temporarily bolted into place so that I can drill the holes in the forward brace and the side flange. The left one fits pretty well, but the forward brace on the right one is hitting the seat rail support and that is preventing it from fitting properly.
Looking backwards from the forward brace backwards you can see where it is contacting the seat rail support.
Looking down at the side of the mount you can see the gap between the side flange and the side of the center section bulk head where the flange is supposed to be. It's about an 1/16" gap.
It's also possible that there is some interference on the bottom too. It kind of looks like there is but I won't know for sure until I fix the issue with the seat rail support.
I'm assuming I'll have to grind away some of the seat rail support so that the mount fits properly, but before I do that I wanted to find out if any others have had this problem and if that was how you fixed it.
