backcountry
I have a 2017 RV-12 all Garmin and the Garmin 200 com
I can’t use noise canceling headsets and I’ve tried several kinds because they pickup noise to the degree nothing else can be heard. On the ground the problem isn’t as bad.
I have to use normal headsets that don’t use noise canceling and they work fine.
I’ve flown nearly 60 years ATP, A&P etc. I consulted with many sources and even Garmin and I have not found a solution and no one seems to have come across anything like it.
