The location of the fuel flow meter is as follows: fuel valve, fuel filter, fuel flow meter, electric fuel pump. The distance between the filter and meter is 2” and the distance between the meter and elec fuel pump is about 5-6” with a 45 deg offset. When I turn ON the fuel pump the gph increases about 6 gal or so. I believe the meter should be between the engine fuel pump and the carburetor, correct?
Is the extra gph when the electric fuel pump is On going out the fuel overflow line from the engine fuel pump? The electric fuel pump doesn’t have a return line like you would have on the electric fuel injection fuel pumps. It’s an automotive Facet fuel pump.
