I am putting together my panel/switches for my -10 and I am at the point of paralysis from analysis. I am working with Stein to cut out, paint, and etch the panels and don't want to make a mistake and wish I had something a couple months after it completed. If you think of something I'm missing please leave comments below. Thanks in advance.
I have 3 10" G3X screens, 507 autopilot, GTX 375, GMA 245 COMM Radio, GTR 20 radio, G5 Back-up Inst with 5AH back up battery. There is also a 6AH system back up battery for emergency power. I selected a voltage meter and emergency power switch the instead of using a relay. The left control panel has the following: Start and magneto switch, master switch, avionics master, pitot heat, fuel pump, right cyclic cutout switch, flap switch. Right side panel: Front seat heat variable control, back seat heat variable control, overhead console air intake valve control, rehostat for defrost/avionics cooling fan, ELT remote switch, CO detector warning light. The experimental warning placard will be above the G3X display on the right side. The Aerosport overhead lighting pod will have switches for Nav/Position, Strobe, Landing, and Taxi switches. Wig Wag is controled by the Vertical Power Pro. Interior lighting has overhead dimmable lights, panel light dimmer, footwell lighting dimmer, selection switch for white/blue LED footwell lights.
Hopefully that is clear as mud but able to paint a picture of what I have planned and now for what I don't know which is were you all come in. Thanks for any input in advance.
Chris
Chris
